How does one Create a Technical Support request for C4R
BIMologist_
BIMologist_
I am trying to figure out an easy way to create a support request for A360 or C4r but there is no option to do so in the drop down list. Or am I just not looking hard enough to get to the link
Case ID: 11967019.
We create it under Revit and it stays in the queue for couple days before it gets answered. Some of the issues needed to be tended sooner than later.
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
BIMologist_
This topic was escalated to Salesforce Case 11968962 on 07/09/2016 by an automatic escalation.
Interestingly The case that was created with Auto escalation I got an answer on that case telling me the options I have.
I am posting the answer here for people to get the answer to this topic. however the case that I actually created with severity set to Critical, I have yet to get a response on. Your Autodesk Support CaseNo:11967019. has been received Case 11967019 - Revit Collaboration for Revit Support v11
Thanks for the answer that I was looking for.
Dear Nauman BIMOLOGIST Mysorewala,
Thank you for contacting Autodesk.
At this time, Collaboration for Revit is not available as a product selection when opening a Technical Support case, it would need to be opened under the Revit product umbrella. Please note, there are different SLAs depending on the Severity Level you set the case to, I might recommend upgrading the Severity from the automatic Level 3 if you need mnore immediate assistance.
Support for A360 is provided either via the A360 Community Forums or by emailing
autodesk.360.customer.success@autodesk.com.
We apologize for any confusion this may have caused you. Please let me know if I can assist you with anything further.
Sincerely,
