Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
A_MAQ
1053 Views, 2 Replies
Hidden door
Hi all,
while i am checking my model using schedule , it appears that this door is exist ,but when i go to 3D i did not see a door
when i unhide the link , the door was exist in link model
but when i hover over the door location in the model not link model
it gives me that there is a model but there is no geometery
what is the problem ?
Autodesk Expert Elite
2 REPLIES 2
laurasmagin
in reply to: A_MAQ
Is the door in the lik or in the host file? (You can check in the schedule by adding the link model name.)
If it's in the host then you may wish to find the door in the project browser and edit the family to check if the visibility is set correctly for your 3D view.
Check your VV make sure it isn't hidden. and there here's a list of 36 items you may also want to check regarding visibility of elements in Revit.
36 steps to being able to 'find stuff' in Revit
Check:
1. The object or category is temporarily hidden
2. The object or category is hidden in the view
3. The object is being obscured by another element
4. The object's category or subcategory is hidden in the view
5. The object is outside the view's view range
6. The view's far clip depth is not sufficient to show the object
7. The object resides on a work set that is not loaded within the project
8. The object resides on a work set that is not visible in the view
9. The object resides on a work set that is not loaded in a linked file
10. The object resides on a work set that is not visible in a linked file
11. The object resides within a group (detail model) and it has been excluded from the group
12. The object is part of a design option that is not visible in the view
13. The object is part of a linked file that is not visible in the view
14. The object has one or more of its edges overridden to display as '<Invisible lines>'
15. The object is a family and none of its geometry is set to be visible in the view type
16. The object is a family and none of its geometry is set to be visible at the view's detail level
17. The object is set to not be visible at the category's detail level
18. The element has been placed outside the view's crop region (visible extents)
19. The element is an annotation object and does not reside entirely within the annotation crop region
20. The object's phase settings or the view's phase settings prevent the object from displaying in the view
21. The view's discipline is prohibiting the visibility of the object
22. The object is affected by a filter applied to the view
23. The object is subject to an element override, set to background colour
24. The object is subject to a category override, set to background colour
25. The object style is set to background colour
26. The object is constrained to a scope boxes that is not visible in the view
27. The extents of the object itself don't permit it to be seen
28. The object is a mass, and 'Show Mass' is turned off
29. The object's host view has been deleted (area boundaries)
30. The view's scale is prohibiting the object's visibility
31. The object is a linked instance with coordinates too great for Revit to handle
32. The user has incorrectly identified the link instance to which the element belongs
33. The object is in a link that is not in its correct position
34. Wall is subsumed by automatically-embedded curtain wall
35. Something is really far away from the middle of the project and when the view is zoomed to fit, everything disappears
36. Element is white and its edges coincide with other objects. E.g., GWB ceiling in RCP.
Give me Kudos or mark as a solution if this helps
Regards
Laura
ennujozlagam
in reply to: A_MAQ
@A_MAQ hello, are you working a working sharing file? see my screencast could be the reason. thanks
