Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
HELP! UNC path not working because files are being saved to drive letter
2 REPLIES 2
adamVCQ2Q
534 Views, 2 Replies
Hello All,
I am a network admin for a Revit using company
I am having this issue with users using the same drawing on a network drive shared on a server. They are mapped to the drive using the same drive letter an path, but when Revit saves, it saves to the drive letter instead of the network path and theirfore will give a error when someone else tries to open the same drawing. Please help! I have not seen how to do this other than using Shortcuts which is a TERRIBLE band aid. Can revit not save via the UNC path instead of the drive letter?
Thanks again gents!
Tags (1)
2 REPLIES 2
ElrinaM
in reply to: adamVCQ2Q
Hi Adam
When multiple people work on the same model, the Central file typically gets saved on a network location. Each user should then make a copy of this file on their local hdd. When they then open this file, they will find the messages you showed. There is a link between the file on the network and the file on their local hdd. When they save, it saves a copy to the local drive.
They need to synchronize to save to the network location.
You can read more about worksharing here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Kudos are greatly appreciated. Everyone likes a thumbs up!
CADPRO Systems
www.cadpro.co.nz
kadmonkee
this is caused by a user opening the Central file directly and not creating a new local file.
this usually occurs when a link needs to be updated.
if (1) user is responsible for managing all Revit models, they should follow the same procedures each time.
the user will need to do updates, then do a save as to update the Central Model, then Sync and Relinquish all mine.
close the central model.
the next user to open the central model should see this dialogue box.
the box Create New Local should be checked (default)
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
