Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
file opened by another user
3 REPLIES 3
923 Views, 3 Replies
When i open any project a popup dialouge tells me that the file is opened by another user so i can not save my project , What can i do ?
3 REPLIES 3
Darin.Green
That would mean the file isn't workshared. When using C4R, you need to create central model and store the central model within the C4R project directory.
Once the Central model is created, you should only open/create a local copy by opening the model while inside of Revit...
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
I am sorry but i do not know what is CR4 ?
Darin.Green
C4R stands for Collaboration for Revit
