Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Failed to open BIM 360 document in Revit 2020 via command line
2 REPLIES 2
Hanley.DengK8R83
479 Views, 2 Replies
I try to open BIM 360 document in Revit 2020 via command line, which looks like:
"C:\Program Files\Autodesk\Revit 2020\Revit.exe" "BIM 360://XXX file/MyTestFile.rvt" /language ENU
Revit starts, and it reports the error: "Failed to open document."
So, my question is: is it possible to open BIM 360 document in Revit 2020 via command line?
If yes, how the command line looks like?
Thank you so much.
2 REPLIES 2
jade.l
in reply to: Hanley.DengK8R83
Per my knowledge, it is not supported.
any reason to do that?
jade.l
Hanley.DengK8R83
in reply to: jade.l
Hello Jade,
We can have the BIM Project Management System, which contains the path of the *.rvt file.
If the *.rvt file locates at local machine, or the network disk, then the Project Management System can open it via command line.
But if the *.rvt file locates at BIM 360, then it is not possible to open it  out of Revit, then it is not possible to open the *.rvt project by clicking it at the BIM Project Management System.
