Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Export Revit sheet to Autocad
1 REPLY 1
saluja.nitesh07
241 Views, 1 Reply
Hi everyone,
I want to export my Revit sheet into Autocad. But there are conditions as I want to see the properties of Revit elements also to be exported as the attributes or blocks in dwg.
For example,
If I open the sheet in AutoCAD, and hover my cursor on Column, I get the properties of Column (namely its size, type, top& base constraints and all other instance properties).
If you know its solution, Please share it with me here.
Thanks.
1 REPLY 1
arjay.eco
in reply to: saluja.nitesh07
I don't think it can be done.
