Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
export IFC | material and void information
0 REPLIES 0
Message 1 of 1
478 Views, 0 Replies
Hi
I create an example in Revit 2016, some walls, windows, doors and slabs.
I export an IFC file with the app, but in the ifc file walls lose the information with IfcMaterialLayer (the thickness) and the relation with voids.
A colleague explain me that it seems that this issue is caused by connection beetween slabs and walls, and maybe if I try to unconnect the elements the information are correctly exported.
Below you can see an image of the file imported in Solibri Viewer: here you can see that the wall selected hasn’t the relation with the void and also the materials haven’t thickness.
In attachments I upload the revit file and I hope that you can give me some suggestion to find a workaround: I think that it isn’t correct to unconnect all the elements.
Can you help me to understand if there's a solution with this issue.
0 REPLIES 0
