Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
E-Transmit cloud model
6 REPLIES 6
garry.bishop
1439 Views, 6 Replies
I am looking to provide a contractor with pdf drawings and a geometry only model. This is achievable with the e-transmit add-in, however it does not allow me to do this for cloud based work-shared models. Allowing access to published files still allows the users access to the sheets and views that are not necessary in data transfer.
Is there a way to transmit a cloud model for this purpose?
6 REPLIES 6
PAAIMJHCN
in reply to: garry.bishop
n_hoffman
in reply to: PAAIMJHCN
Hi PAAIMJHCN, this link appears to have been moved as all I get is a 404 error. Is this information still available?
I am having the same issue with Revit 2023, eTransmitting cloud models produces a model that prompts the user to upgrade from 2009 or earlier, then gives the error "Failed to open document."
Yien_Chao
e-transmit won't works with cloud model.
download a copy with links and then do e-transmit from there.
PAAIMJHCN
in reply to: n_hoffman
Hi Nick
yeah, it seems the page is not available anymore. Unfortunately I don't think there is another way of doing it than the one mentioned before. publish the latest version, download from ACC/BIM 360, and E-transmit from there 😞
Hi @garry.bishop
I agree with @Yien_Chao
Please check this link and follow the steps:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/eTransmit-fails-on...
(It says 2020 but should work for later versions as well)
If this works, please mark this as a solution so that others can quickly locate it. Thank you.
Thank you.
Prateek Chitnis
Strategic Implementation Manager | Product Specialist | AECO (Buildings)
Did you find this post helpful? Feel free to click on the Like button.
Yien_Chao
in reply to: ChitnisPrateek
hi,
what i meant, was the e-transmit not doing proper purge when using ACC models directly.
