Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Duct tags with length inside
1 REPLY 1
marikeE3LVF
190 Views, 1 Reply
Is there a way that I can edit my duct tags so that the size runs along the outside of the duct and the length in the inside of the duct?
I also want to add numbers to the duct segments (makes it easier to install) don't know if it's possible..
1 REPLY 1
pipapongo0909
in reply to: marikeE3LVF
hi,
i guess this should all be possible by creating a duct-tag-family.
create a new annotation family ( i used "generic model" wsince there is no template) an set the category to "duct annotation".
Then place a label and choose the "length" parameter.
repeat this for the size and place it underneat.
you might need to play around a little to get the correct placing but it should be possible.
good luck,
Jeff
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
