Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Dual Monitor Setup for Revit
4 REPLIES 4
!Dalton_Goodwin!
935 Views, 4 Replies
Dual monitors?  Revit 2016
4 REPLIES 4
Should be fine, it all depoends on your graphics card and the size and resolution of your monitors.
The lkimiting factor is the graphics card, not Revit.
Regards
Lars-Ake Johansson
Sr. SQA Engineer
Revit works fine on a single monitor in a multi monitor situation.  You can undock and relocate the properties window, system browsers, etc... to the other screens.  However you cannot open and relocate views to another screen which I believe is the question like you can do with other design tools.
What I usually do, is I minimize the main window, then stretch it across the 2 monitors and then arrange my plans in one screen and the elevations or 3D in the other. Is a workaround to not being able to take views out of the main window. It's a hassle to have to do it every day, but it works. Only takes a min to do it anyways. Hopefully Revit becomes more user friendly in this regard.
Thanks for the info. 2019 Revit has multi monitor functionality now for the views.
