Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
download default Revit 2017 templates (family and project) and content
7 REPLIES 7
Message 1 of 8
pipapongo0909
29799 Views, 7 Replies
Hi Forum,
Our company has a strict internet-restriction philosophy so i have Revit 2017 installed on several machines but the templates are missing ( actually we copied them from the 2016)
I find it pretty hard to find a place where i can download this files. This is not possible since i have no access to the internet on the machines where Revit is installed.
I am about to configure our new 2017 template so i do want to start with the correct library.
Any suggestions?
thanks a lot,
Jeff
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
7 REPLIES 7
Message 2 of 8
mpeperkamp
in reply to: pipapongo0909
Hi @pipapongo0909,
The following link will help you how to add the content libraries and the templates.
Content libraries & Templates
If there any questions about it let it now.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Message 3 of 8
pipapongo0909
in reply to: mpeperkamp
Hi mpeperkamp,
thanks for the quick answer.
your provided link explains how to add content but an internet connection is required which i do not have....
another Question:
Does the templates Autodesk delivers change a lot or will i have the same result if i update my 2015 files?
I have no
thanks
Jeff
Jeff Wurth
LinkedIn
Message 4 of 8
mpeperkamp
Hi @pipapongo0909,
I have in This link de default templates for downloading.
I think there are not many changes from Revit. It is much more important that you can forward the good from Revit 2015 template.
It is much more important that you can work with Revit 2015 template in 2017, upgrade!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Message 5 of 8
pipapongo0909
hi,
thanks a lot.
Jeff Wurth
LinkedIn
Message 6 of 8
gzlaskgzlask
bu dosya olan varsa bana yollarmısınız... acil lazım
Message 7 of 8
gzlaskgzlask
indirme linkini yenilermisiniz..
Message 8 of 8
Re: download default Revit 2017 templates (family and project) and content
