Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Desktop Connector local file location
3 REPLIES 3
Mbruno4XBGX
424 Views, 3 Replies
Is there a way to relocate the local cache for the Desktop Connector?
I have v.16.  The local DC folder is taking up 102GB on my hard drive.
I tried to move the folder to my secondary drive, but the actual folder size is 4.5TB, it won't let me move it.
I really need the 102 GB back on my C: drive.
The source folder is located here C:\Users\<username>\DC
3 REPLIES 3
Basam.Yousif
in reply to: Mbruno4XBGX
That folder is here: C:\Users\<username>\DC\ACCDocs\  but be careful of what you delete! deleting files from the connector folders may delete them from the cloud.
I think what you are trying to do is called 'Changing workspace' and it is explained in this help page: https://help.autodesk.com/view/CONNECT/ENU/?guid=CHANGE-WORKSPACE
If you don't want to mess with that, and just want to clean up your disk space, here is what you can do:
1. You can "Free Up Space" for each hub you are a member:
2. You can also clear your selected projects from the Connector settings. I would keep the selection to a minimum and avoid checking too many projects:
Mbruno4XBGX
in reply to: Basam.Yousif
Thank you.  I think Change Workspace is the way to go to relocate it.
However, I've been trying to use is to archive copies of my models in BIM 360.  But everything I download through the connector won't open in Revit.  So, I have to investigate that further.
Basam.Yousif
Autodesk says the Connector was not meant to be a 'data transfer' tool. If you want to use the cloud for storage, just drag and drop directly to the cloud.
If you want to open those models, they have to be collaborated into the cloud, not just uploaded.
To open models downloaded directly from the cloud (that were uploaded, not collaborated) it's probably better to have them non-workshared.
