Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Desktop Connector 16.5 / Requested Service Unavailable
2 REPLIES 2
bjlottis
226 Views, 2 Replies
I'm in Revit 2022.1.5 and Desktop Connector 16.5.0.2083. I'm trying to get it to reload the keynote text file
Desktop connector seems to be working fine. It downloaded the files from ACC and if I edit a keynote file it's syncing it back to cloud.
But when I try to reload the keynote text file, I get that wonderful error message: "It looks like the requested service is currently unavailable. Please try again."
Any ideas what might be going on and how to fix this?
2 REPLIES 2
omushahwar
in reply to: bjlottis
We had a few users have this issue the fix is definitely tied to the caching.
Revit and Desktop connector should be closed
Go to C:\users\username\ appdata\local\autodesk\Revit clear out the paccache folder and until the revit version 2022\collaboration cache  clear out all folders also go under web services and clear it all out go under desktop connector do the same
Delete the DC folder under your user profile
Then relaunch Desktop connector and let the projects resync and give it a try.
dbutts7
We're also seeing these with some of the add-ins being used, where a file has an extensible storage schema that hasn't been resolved. Make sure all of your users are on the same build/versions for these, that's helped in some cases.
I would also clear the temp folders from Win10/11 and remove as much as you can.
thanks - David B.
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
