Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Deleting files on A360 collaboration for Revit
1 REPLY 1
rverbanac
463 Views, 1 Reply
I am deleting the files from 360 to replace them with updated ones.
Revit is still saying they are there!!
Please help
1 REPLY 1
ukdxb012
in reply to: rverbanac
If you are using C4R, you have to delete the model via Revit... http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU...
This will remove the file from Revit, but it won't remove it from A360, there will still be a file there but you shouldnt be able to connect to it via Revit. To remove from A360, you can use a workaround which consists of moving the Revit file on A360 to an empty folder and then delete that folder.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
