Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
DB Link buttons greyed out
8 REPLIES 8
Message 1 of 9
craig
1144 Views, 8 Replies
After a lot of stuffing around with install of DB link, I have come to a point of desperation.
Revit 2018.2 installed
DB Link installed
MS Access 2016 - 64 bit installed
Display scaling set to 100% - to show the buttons
Now I have the planets aligned, When I try and export to an MS Access database, both the import and export buttons are STILL greyed out. The only option I have is ODBC which doesn't suit me.
ANY ideas why I can't export\import to and Access database.
8 REPLIES 8
Message 2 of 9
in reply to: craig
Try an older version of Access 64bit, 2010 or 2013.
Message 3 of 9
craig
in reply to: ToanDN
Sorry but not an option. We only have a subscription to 2016 and our corporate policy won't allow installation of other versions.
Surely Autodesk work with the latest versions of basic Microsoft software ??
Message 4 of 9
catherineliu
in reply to: craig
Sorry for the inconvenience. We'll look into the problem with Access 2016.
Before a fix is available, you may try the workaround to install Microsoft Access 2013 Runtime from Microsoft website. This component is free and doesn’t require license.
Catherine Liu
Product Owner, Revit
Message 5 of 9
craig
in reply to: catherineliu
The message does not contain any threats
AVG for MS Exchange Server (2013.0.3556 - 4793/15432)
Message 6 of 9
yurikim
in reply to: craig
Thank you for your posting @craig
Also please refer to this for supported versions:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Yuri Kim
Product Support Specialist, AEC
Message 7 of 9
craig
in reply to: yurikim
AVG for MS Exchange Server (2013.0.3556 - 4793/15434)
Message 8 of 9
craig
Sorry but running both a runtime version and full version conflicts with each other in the normal database operations outside Autocad.
Message 9 of 9
Rvadey
Thanks, this worked for me
