Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cut Item Dimension information
0 REPLIES 0
Message 1 of 1
180 Views, 0 Replies
At Thermohouse we have a Passive grade roof system that I have created as a family element with an instance parameter.
This allows the element to be placed on a Work Plane at the required pitch.
we then use a block, (also a family) along with cut command to form roof lights, chimneys and other openings.
when ran through a schedule for take off quantities, the element length being called off is the full length, not cut.
Is there a better way to do this ?
0 REPLIES 0
