Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Custom wall images not showing up in Local file
1 REPLY 1
jappinem
186 Views, 1 Reply
A member of my group made a new wall using a bmp from the internet.  The new walls show up in his local file, and also when he opens the central on his computer.  When I make a local from that central, the walls show up in the default gray.
Any suggestions on how to get the "brick" bmp to also show up in my local?
1 REPLY 1
pipapongo0909
in reply to: jappinem
Hi @jappinem
Do you mean with this that he created a material with the image and then added it to the walltype?
If so: it is possible that the material is saved locally on his machine and not on the server where you also have access?
good luck
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
