Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Connecting pdf document from Docs to revit
6 REPLIES 6
joEBCUK
199 Views, 6 Replies
Hey everyone,
I want 2 things evaluate
1. how can i connect a pdf on ACC docs to a Revit file, for ex. a technical document of a air ventilation group.
If i use the desktop connector, the path is in it (so also the username)
Is there a way to have a path to ACC Docs?
2. if i use collaboration cloud, same problem, is there a way to connect from the CC to docs?
Thx for reading
6 REPLIES 6
Yien_Chao
in reply to: joEBCUK
what do you mean by connect? all you can do is import pdf in Revit i think.
joEBCUK
in reply to: Yien_Chao
No,
I have added a instance field type URL.
So i can add a technical sheet that is on docs.
Problem with the Desktop connector : the path is like  c:\users\name\acc\
So the name is always different for a other user and the path is then invalid.
Yien_Chao
oh sorry for my misunderstanding. did you try by sharing a pdf link in ACC and copy the link instead of Desktop connector? it works.
Yien_Chao
first create a share link in ACC
joEBCUK
Thanks for the solution Yien, i hope i can help you one day...
jo
Yien_Chao
You are Welcome
If it works, mark as a solution 🙂
