Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Communications issue
1 REPLY 1
EduardoVarela8881
247 Views, 1 Reply
We have folowing scenario:
Revit Accelerator in Win 2008R2 server, linked to Host thru a VPN.
Revit workstation in same LAN as machine running accelerator, but with no access to host.
When trying to open Revit file located in host, it not opens and Revit returns an Openning error messagge.
In journal we find:
 Autodesk.RevitServer.Enterprise.Common.ClientServer.Helper.Exceptions.ProxyGenerationException: A problem occurred generating a proxy for the client action, Client Action = BasicAction, Target Node = abcd.def.com, Binding Name = tcpbuffer
 ' 0:<    System.ServiceModel.EndpointNotFoundException: No DNS entries exist for host abcd.def.com.
It seems that the workstation tries to connect to host (here named abcd.def.com), and as host is not accesible from worksastion, it can not open the file.
My question is if when working with Revit Accelerator, the machine hosting the accelerator and also the workstations need to reach the machine working as host, or if we have other problem with the installation?
Best regards and thanks in advance for any advice
Tags (3)
1 REPLY 1
dzanta
in reply to: EduardoVarela8881
is the RSN.ini file created properly on both the workstation and the accelerator?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
