Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Color Scheme uncheck multiple.
2 REPLIES 2
663 Views, 2 Replies
I am wondering if you can Un-Check multiple rooms at the same time for the visibility in the edit color scheme dialog box. i only need a few of the rooms to show the color scheme and there are hundreds of rooms. can i un-check all or select multiple? Shift+ click isn't doing anything.
Thank you.
2 REPLIES 2
Then you shouldn't use the Room number criteria.  Create a new Color scheme that use a different criteria that can be assigned to these Rooms.
Toan Nguyen
Corsten.Au
Its not possible to select multiple..
not even two at the same time..
Cheers!
Corsten
Building Designer
