Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Collaboration for Revit
2 REPLIES 2
vegadiazjean
1389 Views, 2 Replies
Hi
Im having trouble accessing an a360 model. Yesterday I accidentaly erased my collaboration for revit 2017 and i cant access it now. is there any way i can redownload collaboration for revit 2017. I have entered autodesk's webpages and when i try to download collaboration for revit 2017 in the autodesk desktop application there is no link to download.
2 REPLIES 2
@vegadiazjean wrote:
Hi
Glad to help.  The best way to resolve this is to re-run the installer you used to install Revit 2017 in the first place.  That should fix the issue for you.  We released Revit 2017.2 last week, which I'd recommend that you install here, but that's not required.  Re-running the original 2017 installer should get you back and running, albeit on slightly older code.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Darin.Green
in reply to: vegadiazjean
@vegadiazjean
C4R is included in the installer for Revit 2017.2 Update. However, you may be able to fix the issue by running a repair on Revit from Programs & Features.
If this information was helpful, please consider using the Accept Solution
