Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cloud Revit (.rte) file
2 REPLIES 2
chughes
415 Views, 2 Replies
Is is possible to host a Revit template (.rte) file in the Construction Cloud environment?  IE, a centralized place where everyone in remote offices can turn to start a new Revit project, using the cloud based template file.
I have uploaded the .rte to a project folder, but the file is not visible in the Revit Autodesk Docs screen.
Thanks.
2 REPLIES 2
jade.l
in reply to: chughes
Hello, @chughes
The feature you described is not supported yet.  You have to always to start from a local template and initiate the Revit models to the cloud.
jade.l
Ian_Shafer
You can in Revit 2024. The RTE must use "save as cloud model".
I am looking for a way to upload my entire library of families but I cannot upload folders, only files.
Ian
