Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cant't open
1 REPLY 1
zbartosevicius
203 Views, 1 Reply
Cant't open
User cannot open any cloud models in folder
We are having a problem with one particular user as he is not able to open any cloud workshared models in the Link RVT window.
  • The files are visible to that user if one accesses the via the Autodesk Docs drive.
  • The user is running the latest build for the Revit version (2021)
  • The user is running the latest build for Autodesk Desktop Connector
  • The user is accessing the files via External Resources > BIM360
  • The other members can see the cloud workshared models
  • The user has the exact same permissions as the other users
  • We tried removing and adding the project again in the Autodesk Desktop Connector app to reset the cached files
  • we tried signing out, reboot, and signing in again.
  • all links gray
Nothing worked.
Any ideas on what it might be?
Thanks in advance
1 REPLY 1
Yien_Chao
in reply to: zbartosevicius
not the right thing to do here.
user should access like the attached image:
And one stupid question here: does the user have an proper Design Collaboration pro license? Remember : enable the collaboration pro in ACC or BIM 360 for user IS NOT a license, but only an access to. The attribution is through the account manager.
hope that could help
