Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cannot see views and sheets when using Collaboration on Cloud
2 REPLIES 2
bimweera
216 Views, 2 Replies
I am testing the Revit Cloud Project by using Collaborate on Cloud functionality on the Collaborate Tab (not sure if this called C4R?) ...but after publishing,I still cannot see any of them but 3D view even if I had selected some views and sheets in "Publish Settings".
here's the link https://weera2.autodesk360.com/shares/public/SH7f1edQT22b515c761ec1929576217a5fe7
any suggestion ?
2 REPLIES 2
kadmonkee
in reply to: bimweera
depending on which version of Revit C4R you are using, this is a known issue
but the workflow is described in the link
Publish Sheets to Cloud
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
KyleB_Autodesk
That share link is no longer working.  Are you still having trouble with Sheet publishing?
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
