Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cannot publish /Acquire Coordinate when using C4R to collaborate on cloud ?
4 REPLIES 4
bimweera
419 Views, 4 Replies
 I cannot publish or acquire coordinate to/from the linked model when all model are collaborate on cloud.
 Any Idea ?
4 REPLIES 4
yurikim
in reply to: bimweera
What are the paths of the links? Please go to Manage Links and check. Is it pointing BIM 360? Or local?
Also please refer to this:
https://forums.autodesk.com/t5/revit-collaboration-forum/c4r-best-practice-for-linked-models/td-p/62...
Yuri Kim
Product Support Specialist, AEC
bimweera
in reply to: yurikim
Of course it's pointing to BIM360 and when I use command "Publish Coordinate" it's seem like I'm not be able to select any link files.
Is this function available in bim360 C4R?
I believe if the shared coordinates have already been established you cannot updated them on C4R without removing them and a whole workaround.  My suggestion would be to export the models to CAD and figure out where they need to be in there and then use the specify coordinates at a point tool in Revit and manually type them in.  This way you don't have to monkey around with acquiring and publishing not working.
Great suggestion @eschappe_flad_com
Thanks !!
