Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cannot open any model with C4R
5 REPLIES 5
G.Champoux-Sabourin
497 Views, 5 Replies
Since yesterday morning I cant open any of my model.
I receive this message : "An error occurred while contacting the central model which prevents the local model from being opened"
The status is currently working as expected on https://health.autodesk.com/
Am I the only one?
Tags (1)
5 REPLIES 5
Also have this error message : "An error occurred while communicating with the cloud worksharing service."
It may be that a different, but related cloud service was experiencing degradation.
See: Error: "An error occurred while communicating with the cloud worksharing service" appears
when opening a model in Revit
  • Is it still occurring?
  • What version and build of Revit are you using?
  • Which BIM 360 service? Docs or Team?
  • Is this specific to one project? (can you access models in another cloud project?)
Martin Stewart
AEC Support Specialist
Hi Martin
The problem persist since last monday (Jan 7). (it worked well before Holiday vacation)
Revit 2017.2
BIM 360 Team
I've only access at one project with C4R
NOTE : Our general contractor can open the models without problem...Our license is up to date
UPdate
I try to clear files  the follow repertory
C:\Users\%Username%\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\CollaborationCache
C:\Users\%Username%\Local\Autodesk\Revit\PacCache
Now the pop up is
This operation could not be completed
If you are collaborating on a collaboration on a model using the cloud or Revit Server, Check your network connection.
If the problem persists, save any changes to the models locally.
Its now solved...was a problem with the security of https://bim360field.autodesk.com/
Website was considered like unsafe to open.
I can open my model for now and open bimfield.
Thanks for the help
