Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cannot create new local file
1 REPLY 1
749 Views, 1 Reply
Hi I am new to revit
I am having issues creating a new local file. The  "detach from central" file is not grey out, just the "create new local"
I downloaded 3 files the structural, detached architectural, and central model. I saved the downloaded files on my work network, then I opened the central model and do a save as "copy central model" to create a copy of the central model in my own folder. I closed the copied file to create a local file.... and that is where i got stuck.
I would really appreciate your help. Thank you in advance.
Labels (1)
1 REPLY 1
Mohamed-Nassar
check the way that you have to save detached model by check workset is available,,
this problem may faced you also when some one create a new local file you will find the detached only work but new local is not.
Best Regards,,
Mohamed Nassar
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Technology Administrators
