Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Can you change path of local copy
2 REPLIES 2
dmiller2010
290 Views, 2 Replies
Re: Can you change path of local copy - Autodesk Community- BIM 360
When working in the cloud with Collaboration, can you change the path of where the local copy is saved instead of
  • C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\<Autodesk Revit Version>\CollaborationCache ?
2 REPLIES 2
Kelsey.S
in reply to: dmiller2010
Hi @dmiller2010,
It seems you could use a symbolic link. I have not done this myself but the following forum post seems to point to success with this method. See: Hard Disk when use C4R
Please mark any posts that help with "Accept as Solution" and thanks.
Kelsey Skaug
Autodesk Technical Support
Kelsey.S
in reply to: Kelsey.S
Hi @dmiller2010,
I am just checking back to see if my reply to your post is helpful regarding your question.
If it was, please consider clicking "Accept as Solution" so that other members of our community can easily find it and benefit from it.
Thank you!
Kelsey Skaug
