Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Can't link xref from autocad
2 REPLIES 2
veronique_deschenes
208 Views, 2 Replies
I need to link a DWG in my Revit. It works, but the xref from Autocad won't follow so I get almost nothing to work with. I am working on ACC so we can share out model with other people. All files are there (RVT and DWG) and everything is linked via autodesk docs. Any idea ?
Labels (6)
2 REPLIES 2
In AutoCAD, is the XREF set to overlay or attach? It should be attach.
Personally, I try to avoid nested references. It's much easier to control them when they are a direct reference.
That was it ! Thank you so much !
