Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Can't create local file...
4 REPLIES 4
910 Views, 4 Replies
All of a sudden one of our users isn't able to create a 'new' local file from A360.
The user is receiving the "Your local file is not compatible with the central model" message which doesn't make sense to us as he's been able to since the beginning of the project.
All of our machines are using
Build: 16.0.1124.0
20160314_0715(x64)
Update4 for R2
with;
Autodesk_Collaboration_v5_for_Revit_2016
as far as we can tell, nothing has changed since these last updates we installed a few week ago.
Has anyone else experienced this behaviour?
Thankyou.
4 REPLIES 4
matthew.d
Hi @Anonymous,
Sorry about the issue. This typically happens when someone is working on the central model or two users have the same username. Give the solutions posted here a try.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
in reply to: matthew.d
thanks for the info.
our model is in the a360 space. this particular user has been accessing it without error for sometime now.
the error still persists after a clean reboot and a clean user-logon.
matthew.d
Hi @Anonymous,
The user hasn't changed his software version? The central file wasn't changed in any way, such as naming structure or is not being worked on?
Matt DiMichele
Thanks Matt for the follow-up.
turns-out we figured it out. the user didn't, or wasn't able to, save previous changes from a previous session.
after discarding changes from the local, the user is able to open to model as usual.
user error was the culprit and luckily there was no significant data loss.
thanks for your help though!
-md
Technology Administrators
