Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Can't Change Issues To Closed
4 REPLIES 4
Nathan.HilsonN67V6
227 Views, 4 Replies
Has anybody else run into a problem where an issue that's assigned to an individual cant be closed by that individual once that issue has been resolved. Is this an issue with the way the permissions are assigned?
4 REPLIES 4
Hi. Can you tell me more about what kind of "issue" you're attempting to close; is it a sheet issue in Revit? When you try to close it, what error message(s) are you seeing?
Kevin Short
Senior Product Owner
For this I'm referring to the issues added through BIM Collaborate Pro. When managing the issues from within Revit, the assignee is unable to change the issue to closed. Only "Pending" & "Review". I'm assuming it has something to do with the permissions set within ABC Pro but I have their rights set to full edit. Next step up would be full administrative but I wouldn't want everybody with these types of privileges.
hi
there is permissions on folders and permissions on issues. this one is access through the settings of issues.
hope that might help
@Yien_Chao  Thanks, this is exactly what I was looking for.
