Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Can see new Uploaded Files In A360
2 REPLIES 2
tomasportugues
289 Views, 2 Replies
I am using A360 with Revit. I have been using it without a problem opening the central file through the A360 server but as I started to create/upload more files now I am not being able to see them any more (I can still see the ones I originally had, not the new ones) when I try to access them from Revit.
Thank you
2 REPLIES 2
These "new" models, are you uploading them to the BIM 360 Team site, or through the Revit UI?
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Thank you for your post.  In this case, it looks like you are attempting to upload a new model to BIM360 team hub through C4R and are not seeing the latest models you have attempted to upload.  Do I understand this correctly?   You mentioned that they were working fine, but there seems to be a change on the system that prevents this.  If this is the case, can you link this back to a potential change on the system that could be contributing to this ill behavior (IE an update to windows, a software update to C4R or Revit).
Potentially, how are you also uploading these models to the hub?
Getting projects into the hub:  https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
For reference:  https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
In addition to this, please take a screen shot of your version for Revit and version of C4R from the control panel to help identify current build.  Please also identify what operating system you are seeing this on please.
Please keep us posted in the community and let us know how we can best help moving forward.  Thank you and we look forward to your reply.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
