Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
C4R version check
3 REPLIES 3
jagostinhoCT
386 Views, 3 Replies
C4R version check
Where can I check which version of Collaboration for Revit has been installed on a workstation?
The Revit About window does not mention it.
The Windows Programs and Features is not clear on whether it is version 4 or 5 of C4R.
Thanks.
J
Assistant BIM/CAD Manager
Manchester, UK
3 REPLIES 3
N.Oomen
in reply to: jagostinhoCT
Hello jagostinho,
To find out what version you use for C4R you could use two options. (first one you did already)
1. Open your Programs and Features in windows and search for “Autodesk A360 Collaboration”
You will find the Vx version with the older Revit version.
Newer versions will not give you a Vx, so the only way to verify that one is to go to step two.
See Attachement.
2. Go to the correct Link below and download latest C4R:
Revit 2015
Revit 2016
Revit 2017
I would really like to hear if this helps.
Good luck,
Niels Oomen
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
jagostinhoCT
in reply to: N.Oomen
@N.Oomen
Step 2 is not clear to me. If step 1 does not work, I need to download and install it again? How would that help?
Cheers,
J
Manchester, UK
N.Oomen
@jagostinhoCT
If it is not visible with the first step, I would say Autodesk could improve on that, but to make sure you get everything to work you could follow step two.
When you reinstall you will know for sure you have the latest installed, then version isn't really important just that it is the latest.
If everyone works with the latest updates it gives the least of problems is my experience.
Niels
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
