Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
C4R stuck on folder loading
3 REPLIES 3
Benlwatts
293 Views, 3 Replies
Hi All,
When using C4R can you have 2 different version of Revit open ?
I seem to get an issue when ever I'm working in one version and then have to open up a different version to make some minor modifications. that when I come to choose the project folder it just stays on loading until I close both versions and then re-open the version needed for C4R
3 REPLIES 3
leemichaelb
in reply to: Benlwatts
If you click on Revit's help button, select "About Autodesk Revit 20xx," and then click the license info button, do you find that your two versions of Revit are licensed using two different serial numbers?
Mike Lee
Autodesk C4R QA
Michael B. Lee
Principal QA Analyst
Benlwatts
in reply to: leemichaelb
Yes two different versions both with different serial numbers
Hello @Benlwatts
A possible workaround that might work in this case is to start the second instance with 'Run as a different user' (Shift+Right Click) on Revit.exe or Revit icon
Does this allow you to resolve the problem?  I look forward to your reply.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
