Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
C4R Publish Settings
6 REPLIES 6
bim
524 Views, 6 Replies
Whenever I access my C4R project in BIM360 Teams, the only thing available is the default {3D} view.
When I go to the Publish Settings in Revit, I select sheets & views and get the message as seen in the attachment
"Warning
Because you did not select any views or sheets, only the default 3D view will be published on A360."
You can see in my screenshot that I have sheets selected. I have tried this multiple times and get this message regardless of which combination of sheets / views / sets I select.
6 REPLIES 6
andrea.kikuchi
in reply to: bim
Hi @bim
Have you initiated the model via C4R into the project on BIM360 Team? You will have to do this first before you can choose views to upload.
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Kevin.Thickett
in reply to: bim
Is there a reason the "include" box adjacent to Set 1 is unticked?
Presumably you tick this before pressing save & close.
bim
in reply to: bim
This particular C4R project currently has (18) RVT files loaded to it. All of them have been published to BIM360 Teams at least once. All (18) models show this error when trying to change the publish settings in Revit.
All of the models on C4R ONLY show the default 3D View. None of the views or sheets are populated.
bim
in reply to: Kevin.Thickett
I receive the same error message if the Set is checked or not checked.
The plan is to utilize a Sheet Set to manage the published sheets yes, but the error shows up no matter what combination of sheets / views / sets I select.
bim
in reply to: bim
Given that these projects were fresh / brand new, they did not have a Sheet Set created. Set 1 was not a REAL set, but a Revit Database placeholder.
Once we created a new Sheet Set, assigned sheets to it and published, things are working properly.
andrea.kikuchi
in reply to: bim
Thanks for the update, glad it's working now!
Andrea K
