C4R not deleting central model
jwarner4
Message 1 of 8
jwarner4
I have tried, from multiple PCs and cannot delete one of the central models in C4R 2016. I have all of the latest updates. I can also delete other models, but this one fails to delete.
Thank you,
Jac
Replies (7)
Message 2 of 8
assuming you're attempting to delete from within Revit (Collaborate>Manage A360 models...) and not from A360; as a  test, can you rename the model at least?
Message 3 of 8
AdamPeter
I've also seen the model get into a state where you can't delete after a failed publish.  Can you try a Sync with Central, republish, and then try to delete the model again?
thanks,
Adam Peter
Customer Program Manager
Message 4 of 8
jwarner4
Yes, I've been using the "Manage Models on A360" to delete the files.
Message 5 of 8
jwarner4
Adam, I have tried this and had no luck.
Message 6 of 8
AdamPeter
Sorry to hear this continues to be an issue.  Can you PM me your journal from the Revit session you tried to delete?
Adam Peter
Message 7 of 8
jwarner4
I tried this exact order. I opened the model, synced. Closed out of the model. published. and then I was able to successfully delete it.
Message 8 of 8
thanks for the follow-up and info. glad you got it resolved!
