Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
C4R Models not Publishing to A360
7 REPLIES 7
Message 1 of 8
Victory1
386 Views, 7 Replies
Hi
I am having an issue with a project where the main central file that has all the links in it is not publishing.
Have tried via a series of different users and all are on the latest C4R plugin updates. project is Revit 2016.
all other models in the folder publish fine.
But not the main central. which is only about 10MB.
Journal files attached.
Any advice much appreciated.
Andrew
Tags (2)
7 REPLIES 7
Message 2 of 8
AdamPeter
in reply to: Victory1
Thanks Andrew, let me take a look at the journal and see what I can provide some assistance.
Adam Peter
Customer Program Manager
Message 3 of 8
Hi Andrew,
Thank you for taking your time to post this on the forum,
As it's file specific would it be possible for you to share the files with me? I'll try to run some diagnostics on it and see what I can find.
Let me know if that's possible, I've sent you an invitation to a folder,
Best Regards,
Jacob Westergaard
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Message 4 of 8
Hi Jacob,
Thanks for the offer.
Your colleague Rafal Gaweda has been trying to resolve the issue.
I'm happy to send you the model also, but its worth you liasing with him so that you don't both overlap with things you are doing to troubleshoot it.
Andrew
Message 5 of 8
Hi Andrew,
Thank you for letting me know,
I'm sure my colleague is handling it just fine so I'll let him finish his work.
Best Regards,
Jacob Westergaard
Jacob Westergaard
Message 6 of 8
What was the solution to this problem as I am running into publishing problems as well.  I am using Revit 2017 and when I select publish all files to BIM360, not all the files are updated.  Any news on how to fix this?
Message 7 of 8
Publish all only updates models that have changes to them.  Is it possible that the ones that didn't publish were already up to date?  In the Manage Cloud Models dialog there should be an icon for each model (either a green circle with a check for those that are up to date or a box with an arrow pointing up for those that can be published).  Can you provide some specifics of models that are ready to publish that are failing on the publish all?  You may also try to publish them individually to see if there is an issue with just one specific one.
Adam Peter
Message 8 of 8
Thanks for the email. I did find out that those files haven't been updated in a while.
Best,
Aracely
