C4R Model Publishing
I am also having problems publishing models to A360 using C4R. I have noticed on our particular project there are three models that have this problem. Each of these models is publishing the same model that is not one of the three and each one shows a file size of 0 bytes.
AdamPeter
This is a known issue that is being worked on. I would be curious if you follow the steps from this thread (http://forums.autodesk.com/t5/revit-collaboration/c4r-publish-not-working/td-p/6315169) if you are able to download the file correctly from A360?
thanks,
Adam Peter
Customer Program Manager
Adam-
Yes, when I download the models with this issue everything is included in them and nothing is lost.
