Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
C4R model not showing on BIM 360 team
3 REPLIES 3
EKalaf
342 Views, 3 Replies
I'm working in the cloud and one of the models that I can access through C4R is not showing up on BIM 360 team. Also when I try to publish that same model it always gives an error.
Any Suggestions?
Esmail
3 REPLIES 3
johannes.bjarnason
in reply to: EKalaf
Im having the same problem..
would love to see some answers or support for this!
regards,
Johannes Bjarni
yurikim
in reply to: EKalaf
Thank you for your posting @EKalaf
What happens if you access BIM 360 Team? Do you see your project and some models? Is it limited to certain model(s)? Or you don't see the entire project?
What is the error message when you publish your project?
If you have any issues accessing in BIM 360 Team, I would suggest to open a case so that we can investigate this further.
Yuri Kim
Product Support Specialist, AEC
for me I see the project, and all the models execpt this one model which is the Arcitectural model.
I am Admin of the project and I did all the uploading, but this one model file is not visible, but is visible inside C4R in Revit.
Johannes
