Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
C4R 2015 v11 crash for a user
2 REPLIES 2
nmysorewala
298 Views, 2 Replies
We are running into the issue again where Revit will crash opening the c4R model completely fresh.
He was crashing a few days ago and lost some work as the local would not sync with c4R
He got the Not enough quota error
so we completely deleted his ParCache and Collaboration Cache, Temp folder emptied.
We are trying to open it again clean slate and he is still crashing and getting the error
We have tried multiple times to open the model. In the past this was an issue for another user and it resolved it self.
Other 9 users in our office plus 6 at other consultant office are working fine without issue.
Original case [CaseNo:11967019.] Revit Collaboration for Revit Support v11
In it the tech mentioned that "We have an article about this issue that is in the process of being published, so when that happens I'll send you a link to it so you can follow along whenever any updates to the article are posted. "
I tried search the Autodesk website, and I thought I would find something (thats another story) but did not find anything on the topic.
Any help would be appreciated
'C 16-Sep-2016 08:47:26.365; 0:< started recording journal file
' Build: 20160512_0715(x64)
' 2:< Managed exception occurred:
'C 16-Sep-2016 09:37:07.375; 2:< Not enough quota is available to process this command
'C 16-Sep-2016 09:37:07.375; 2:< ExceptionCode=0xe0434352 ExceptionFlags=0x00000001 ExceptionAddress=000007FEFCE1A06D
I also see these errors as well in the file
'context_call: PAC cache miss
'context_job: Model Open
'duration: 291
'facets_included: skybase, skyclient
'skybase_correlation_id: fafdce1b-f1fd-4b3c-b4fe-2df7a94c78fc
'skybase_model_guid: 04fcba87-10a7-4289-ae26-c446f6c90b5f
'skybase_model_size_bytes: 0
'skybase_project_guid: 6f0e7045-bada-4e07-bc53-5be8f3692e07
'skybase_version: 1.0.0
'skyclient_element_count: N.A.
'skyclient_model_delta: 415
'skyclient_version: 1.0.0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=ElementStream, number=1516), Revision=19): ModelSessionToken: User's Name pmooreDU24E, User's Machine Name MOOREW540, Operation GUID df397e06-032e-4e38-a13b-a2ed11efdc1b, Central server = "model15.skyscraper.autodesk.com", Path = "CUT_ARCH_13513_R15.rvt",
' 0:< Cache miss [1516_1.rws]
' 0:< Time: 9/16/2016 08:51:40:678 Calling: GetDataURI
' 0:< Starting GetDataURI of ModelDataResourceInfo(ModelResourceId(type=ElementStream, number=1516), Revision=19)
' 0:< Retry Count: 0 . Caught exception:
' 0:< System.TimeoutException: The request channel timed out while waiting for a reply after 00:00:09.9929993. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< System.TimeoutException: The HTTP request to 'https://model15.skyscraper.autodesk.com/ModelService2015/ModelService.svc/basichttpfast' has exceeded the allotted timeout of 00:00:09.9920000. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< System.Net.WebException: The operation has timed out
' 0:< Time: 9/16/2016 08:51:50:713 Calling: GetDataURI
' 0:< Retry Count: 1 . Caught exception:
' 0:< System.TimeoutException: The request channel timed out while waiting for a reply after 00:00:09.9139914. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< Time: 9/16/2016 08:52:00:738 Calling: GetDataURI
' 0:< Retry Count: 2 . Caught exception:
' 0:< System.TimeoutException: The request channel timed out while waiting for a reply after 00:00:09.9649965. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< Time: 9/16/2016 08:52:12:762 Calling: GetDataURI
' 0:< Retry Count: 3 . Caught exception:
' 0:< System.TimeoutException: The request channel timed out while waiting for a reply after 00:00:09.9719972. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< System.TimeoutException: The HTTP request to 'https://model15.skyscraper.autodesk.com/ModelService2015/ModelService.svc/basichttpfast' has exceeded the allotted timeout of 00:00:10. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< Time: 9/16/2016 08:52:26:787 Calling: GetDataURI
' 0:< Retry Count: 4 . Caught exception:
' 0:< Time: 9/16/2016 08:52:42:811 Calling: GetDataURI
' 0:< Retry Count: 5 . Caught exception:
' 0:< System.TimeoutException: The request channel timed out while waiting for a reply after 00:00:09.9769977. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
' 0:< Exception ]
' 0:< logAnalyticsRequest_
' 0:< Keys Count: 14
' C 16-Sep-2016 08:52:52.846; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'api_category: Analytics
'duration: 72165
'skyclient_model_delta: 0
'status: ERROR
' 0:< Thread "RevitSrvToolDownloader_0" terminating due to error.
' 0:< Thread "RevitSrvToolDownloader_0" failed to download file "1516_1.rws".
' 0:< Download thread failed.
' 0:< Failed to download one or more data file(s) for model "ModelLocation(model15.skyscraper.autodesk.com:CUT_ARCH_13513_R15.rvt)".
' 0:< Dumped directory: C:\Users\pmoore\AppData\Local\Temp\Revit_ModelDataFileDownload_19f2b461447946b9a39b890a9e5cd708 and its contents.
BIMologist
Tags (2)
2 REPLIES 2
AdamPeter
in reply to: nmysorewala
Sorry to hear about this issue.  Can you please PM me the full journal file?  I will start researching with what you posted as well.
thanks,
Adam Peter
Customer Program Manager
nmysorewala
in reply to: AdamPeter
Adam Thanks again for looking into this. I have Judy/Lars-Ake looking into this [CaseNo:12174942.] currently.
Additional information: Not enough quota is available to process this command and the size of our model too.
No definitive yet since it is an intermittent issue.
It could be linked to this issue but the editing of that registry and increasing the value is not recommended.
http://forums.autodesk.com/t5/revit-api-forum/revit-2016-r2-r2-update-1-r2-update-2-dwf-export-api/t...
BIMologist
