Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
BIM Collaborate Pro Assembly Colors In Model
4 REPLIES 4
Nathan.HilsonN67V6
483 Views, 4 Replies
Is there a way to get the colors of either the assembly or the systems to show in the cloud when using the model coordination?
4 REPLIES 4
In order to better help you, may I ask: What product are you working with - Inventor? Revit?
Kevin Short
Senior Product Owner
I'm working in Revit.
Okay, you're working in Revit - thanks.
Can you give me an example of what you're doing, what you expect to see in the cloud, and what you're actually seeing? From your earlier description, I'm thinking you're creating a model, specifying a specific color for one or more element(s) in the model, and then saving that model to the cloud. But when you open the model from its cloud location, you're not seeing the color you specified on the same element(s). Is that correct? Can you give me a little more detail (screenshots or video clips are great if possible)? Thanks!
Kevin Short
Yes that is correct. Specifically the assembly and or system colors.
