Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Bim 360 team button in revit 2017 (the big blue B) is not working.
6 REPLIES 6
ArtisanCAD
359 Views, 6 Replies
it was fine yesterday? I can't access my cloud models
Lorne
6 REPLIES 6
ArtisanCAD
in reply to: ArtisanCAD
Ok. this is now resolved. It was caused by the latest windows 10 update. I rolled back to the previous version and all is good.
Lorne
ArtisanCAD
Well, this problem is back. I am now in a situation where I cannot roll back windows 10 latest update. as soon as I remove it windows just updates again. Apparently windowd 10 updates are not able to be stopped.
again I find that I cannot access my collaboration files in 2016/17 or 18. I am at a loss.
Lorne
sureshchotrani
Are you on latest Revit build, https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Did you try repair via control panel?
If you are still facing issues you can uninstall BIM 360 from the control panel and reinstall the same.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
ArtisanCAD
in reply to: sureshchotrani
Thanks for you reply.
yes I have tried all of those options. In fact all my Revits 2015/17 and 18 do not now see collaboration.
I think somewhere along the line a windows install on my main tower has corrupted some files as my laptop works fine with both the latest Revit and Windows 10.
Looks like I need to do a new clean windows install
Lorne
Had the same issue for v2017 and v2018. I reinstalled the latest update for each of the version and the issue(s) were solved. Repeated this on a secondary machine Revit 2016 was uninstalled), but the same result: no "B" available. Applied the latest updates for v2017 and v2018: all fixed.
Not that I'm hoping the issue will occur again. Not that I know the reason (that Autodesks thing to find out). But at least we know how to fix the error.
Thierry
Thanks for your input
Yesterday I did a clean install of windows and then updated windows to the latest version 1709. Then I re-installed revit and everything is working now. what a megga pain in thre rear
Lorne
