Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Bim 360 revit file is not the same as C4R revit file???
1 REPLY 1
bjur
465 Views, 1 Reply
Why is my revit file on Bim 360 not the same as the C4R Revit file we've been working on via the cloud.  Listed below is the file as shown through the Bim 360 Viewer.  The other is the same file as shown when opening the same revit file through C4R.  Why are these files not the same?
1 REPLY 1
Melina.Vlachousi
in reply to: bjur
They're not supposed to be the same. Other than the file created when you first start your Revit Project in the Cloud, the files you see in BIM 360 Team are the files you publish from within Revit.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
