Revit Cloud Worksharing Forum
Welcome to Autodeskā€™s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Bim 360 file says its corrupted
6 REPLIES 6
ewardD69VP
463 Views, 6 Replies
Hello
So I'm working on a project and a tab opened saying the file is corrupt and needs to manually recovered, as seen in the image attached (I did cover the name because I don't know how public my project is yet, but for reference the things covered in blue say the same file name (I have seen some where they are 2 different files) but mine say the same and purple is the overall name of the file, no biggie)
This message has come up for others in the office on this project but would eventually open, while mine has been loading for about 2 hours and this is my second attempt opening it, the first attempt I let it load for an hour before closing Revit.
6 REPLIES 6
RSomppi
in reply to: ewardD69VP
What is your question?
Have you tried opening the project and all links with an audit?
Have you tried manually recovering?
ewardD69VP
in reply to: RSomppi
Is there anything i can do to open it? Because I dont own this and other people are on and are using the file, i dont think recovering is an option.
How would i open all the links with an audit?
RSomppi
You probably need to talk to the authorities having jurisdiction.
ewardD69VP
Okay, i can see, they were with me when it was taking forever cause they seemed confused as well. I asked our IT guy but he is in a meeting and is 3 hours behind me.
jade.l
Hi  @ewardD69VP
Could you please try the solution below to get a new local copy from central?
How to clear a corrupt/damaged cloud workshared model or outdated link from the system in Revit (aut...
If the issue persists, please contact your product support for further data investigation.
jade.l
ewardD69VP
in reply to: jade.l
I appreciate both your help! The problem, at least for my case, was so stupid... I had to update Revit... embarrassing
I had a bad case of user error.
