Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
BIM 360 Design - Freeze when saving to central
24 REPLIES 24
Message 1 of 25
sampie
8187 Views, 24 Replies
I am creating this post on behalf of a customer. When synchronizing to central using the Revit Cloud Worksharing on BIM 360 Design Collaboration, it will sometimes get stuck at "Save to central" on 3.5KB remaining up to the point where one has to close Revit via the Task Manager. Has anyone experienced this issue and if so, what would be the cause? The Internet Speed is fine (40Mbps Fibre).
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
24 REPLIES 24
Message 21 of 25
dhenkePWD9T
in reply to: PeterH
Interesting. The Enscape downgrade to previous version solved it for us (at least for now). Are you using the cloud version of keynote manager or local server?
Message 22 of 25
alexanderc
in reply to: dhenkePWD9T
We do use Revolution Design Keynote Manager (for now), but haven't been able to link to anything with it causing a freeze like this. We don't use the cloud version, so perhaps that is what the culprit is. Have you been able to temporarily disable it and see that it continues working without it? That's how I found Enscape 2.8 as our culprit.
Message 23 of 25
dhenkePWD9T
in reply to: alexanderc
I was responding to Peter H, who says he is not using Enscape and is experiencing the BIM360 freeze. Per my previous post, I downgraded from Enscape 2.8 to 2.7 and the freeze stopped. Knock on wood.
Message 24 of 25
in reply to: sampie
 Our BIM IT Department solved our problems with this
Here are the steps:
-Exit Revit 2018
-Open up this folder:  ProgramData/Autodesk/Revit/Addins/2018/<COMPANY NAME DELETED>/Contents
-Open the Pantopes.ini file
-Change this 1 to a 0 (highlighted below)
Message 25 of 25
r.robert.bell
I need to point out that Panoptes is a company-internal add-in, so this solution won't be applicable to folks outside of the company.
R. Robert Bell
BIM Manager
Stantec
Technology Administrators
