Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
best approach fo implementing C4R and BIM 360
3 REPLIES 3
kadmonkee
373 Views, 3 Replies
having dealt with this in the past I know it works in a static environment, while under 1 or 2 contracts within the office.
my scenario now is this
3 office locations
2 offices are on a license server under contract.
1 office is all users are standalone locked permanent seats. ( I know not the ideal situation)
my question is- if we purchase seats per user C4R, do the serial numbers need to match the contract number, or the users serial number.
we are currently running 2015,16,and 2017.
thank you for any help in this issue.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
3 REPLIES 3
pmarchese
in reply to: kadmonkee
Nope, the C4R entitlement is user based and you can assign them to anyone. You just need to install the plugin on the local computers (depending on version of Revit this may already be installed) and ensure that each Revit user is invited to the project on BIM 360 Team and is granted a license/ entitlement to the C4R service. If need be you can grant that entitlement to users not from your company as well.
peter-
Peter's response above covers the solution to your question.
But be sure to review this article too:
A360 Team: Contract Assignment Workflow
Also, here are some more good references on C4R and BIM 360 Team:
AR17677: The Nuts and Bolts of BIM 360 Team and Collaboration for Revit
On-Demand Webinars on Cloud-Connect BIM / C4R
How to Get Started with Your A360 Collaboration for Revit Subscription
Collaboration for Revit 2018 online help documentation
A360 / BIM 360 Team online help documentation
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
thank you I will review those docs
if i have any furher questions I will reach out to you.
thank you
