Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Austria Content in 2016 reduced by 1.365 files
4 REPLIES 4
andreas.polak
510 Views, 4 Replies
Why the Austria Content was reduced in Revit 2016 from 5.768 to 4.403 files? - This means a loss of 1.365 files or 0.49 gigabytes of data volume.
4 REPLIES 4
huotger
in reply to: andreas.polak
Andreas,
Thank you for participating in the Revit Answer Day.
For Revit 2016, there was not a significant change to the content installed when Austria content is selected at time of initial installation.  However we have seen a complication with Austria content under the below installation scenario:
  • Install Revit 2016 with German content
  • After Revit 2016 is installed, add Austria content via Revit 2016 Content Libraries in Add/Remove Programs
  • Result is that the German content, which is already installed, is not reinstalled with Austria content.
Does the above installation scenario match how you are installing Revit 2016?  If not, can you further describe how you are installing Revit 2016?
I hope this helps explains why you are seeing a difference between the release versions.
Gerry Huot
SQA Manager
andreas.polak
in reply to: huotger
I`ve installed it directly at the beginning of Installtionprocess with the choice of content: Germany, Austria, Australia an NewZealand.
huotger
Andreas,
We would need to validate your direct scenario to see if there is yet an additional issue we were not aware of.
Furthermore, the German and Austria content share the same German MEP content library.  All of the German MEP content should reside in the Germany content folder and can be directly copied into the Austria content folder if you would like to have the content present in both locations at this time.
If this answers your question adequately, please select the Accept As Solution button.
Gerry Huot
SQA Manager
andreas.polak
MEP Content in library Germany includes 1.789 Files or 530MB. MEP Content in the library Austria includes 1.717 or 507MB. Only a difference of 83 files. Were are the other 1.283 files lost?
