Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Augmented Reality for Revit
2 REPLIES 2
ennuyda
882 Views, 2 Replies
Hi guys,
Does anybody tried Augmented Reality (AR) for Revit? My boss is about to purchase Meta 2. I don't know if this unit does already supports Revit files or at least any 3D authoring softwares.
You can check the Meta 2 with the links below.
www.metavision.com/gettingstarted
https://www.youtube.com/watch?v=lIbIQ-1Vxi8
https://www.youtube.com/watch?v=_x9462x6A0k
Thanks in advance!
Erix
2 REPLIES 2
BIM_Cardial
in reply to: ennuyda
I was working with VR, using HTC VIVE and RIFT.
If you use REVIT and REVIT LIVE ( https://www.autodesk.com/products/revit-live/overview ) you can connect each one and navigate directly. It´s plug & play.
I didn´t have opportunity to use this Meta device. And never saw any reference to it or other AR device using Revit Live.
What I know is that you have to prepare your model, made in any 3D software, in a specific Animation software to setup the enviroment to AR. It´s not a plug&play, but yes, you can do it.
Autodesk has Stingray, that now is available inside 3dsmax 2018, now called "3dsmax Interactive".
https://www.autodesk.com/products/3ds-max/features
Ricardo Cardial
Arquiteto Urbanista - Mentor BIM
BIM | Nuvem de Pontos na FARO do Brasil
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta
Clique em Curtir se gostou.
Autodesk Community
site8MSRC
in reply to: BIM_Cardial
I would advise you to read a little more about the development of augmented reality -https://bit.ly/2GPjeqz , not so long ago I found a guide to developing augmented reality, I hope this information will become useful
