Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
attached walls and columns to linked model
2 REPLIES 2
A_MAQ
988 Views, 2 Replies
Hi all,
is there a way to attach walls or columns to a slab in linked model ?
thanks
Autodesk Expert Elite
2 REPLIES 2
www.TechRoom.bg
in reply to: A_MAQ
You can't attach your walls to elements in linked model.
Your basic solution is to use copy/monitor. When you copy slab from linked model you can attach your walls.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
As mentioned Copy monitor is the way to go for Walls, Floors, Columns & Levels. When you're trying to connect to things that aren't copy monitor able (other than Walls, Floors, Columns, Levels) What I do is click and select the link, tab and select the element/s you need to connect too (Usually a beam). This will highlight it. From there you can CTRL-C then go to the modify tab and paste aligned to same place. Make sure you put it on a workset that you can exclude from views quantity schedules etc. Keep in mind that this method will not notify you of a change. Best for existing conditions that aren't likely to change.
