Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
PEDWARDS9U3P4
246 Views, 1 Reply
Assemby Issue
Is there a way to add another Naming Category to a New Assembly?  Currently there is only:  Generic Models, Structural Foundations and Walls.
I would like to create multiple assembly sheets of a concrete building.  But some of the wall panels of the building are the same. I can only create numbered assembly sheets using these three categories .  Having  a fourth panel that is similar, there is no longer an option to keep the assembly sheet numbers in order.  I need to be able to keep track of parts put into the panel.
Any suggestions?
Thank you for your time,
Pam
1 REPLY 1
The workaround seems to be slightly changing the name of a part(family) in the assembly and loading it into the project with something as simple as an underscore.  This then allows a new assembly to be created.
